SiemensTM Material Data Center (SMDC) provides accurate multi-domain material properties to enable the creation of sustainable, efficient, and lightweight designs.
An administrator is provided access to the SMDC Dashboard to access specfic administrative related tasks to maintain up to date information in the Simcenter Material Data Center.
Review material data and publish or unpublish it to the database.
Here’s a quick look at the latest features available with Altair One.
Explore collaborative access to simulation and data analytics technology plus scalable High Performance Computing (HPC) and cloud resources, all in one place with Altair One.
View a video to learn about the latest features of Altair One.
Sign-in to gain quick access to the Altair One applications to create appliances, manage your files or folders, browse through Altair and Altair Partner applications, community and support channels and to view your license usage.
Altair One enables users to run cloud-based simulations using the Altair License Units.
Altair One Home provides quick and easy access to your pinned applications, running desktops, recent jobs and files, and default and shared appliance statuses.
Administrator Dashboard portal providing real-time license usage for Altair managed license subscriptions.
Altair Dashboard is an administrative portal providing real-time license usage for Altair managed license subscriptions.
Altair Marketplace is a digital catalogue that you can use to find, try out, and buy Altair's and Altair Partner simulation applications and services.
Simcenter Material Data Center is a web-based tool accessible through all leading browsers. Launch the application to access the material data. You can customize and launch the application from Favorite Apps, on the Altair One Home page.
SMDC provides license types such as Guest User, Viewer, Explorer, and ExplorerPlus. These are supported by Named User Licenses and Altair Units-based License models.
The Stick-Slip Database provides access to over 11,000 individual measurements covering a wide range of common materials available on the market.
Get instant access to an exhaustive database with thousands of simulation ready materials directly from within Altair desktop applications! This seamless integration automatically lists materials suitable for the application and lets users look up, search, compare and download CAE-ready material cards directly in the software.
Here’s a quick look at the latest features available with Simcenter Material Data Center.
Discover the features of SMDC with step by step tutorials and videos.
Search a material or a list of materials using quick search, advanced search or scatter plots.
Select one or more materials to compare the chosen materials data.
Browse and filter materials using the predefined categories as filters in the left navigation pane that most suit your requirements.
Find similar materials in terms of mechanical, thermal, or electrical properties.
Visualize advanced and accurate material properties and curves. Also, view material impact using Global Warming Potential (GWP) and set your data preferences.
Export material data sheets with plots as a PDF and CAE simulation-ready material cards to your workstation or Altair Drive.
Share material information in an email, document or message. Recipients of the link can view the material information in SMDC.
AI assistant for SMDC.
Customize the materials data in table view. Add, remove material properties as table columns, reorder the columns, and sort them.
Set theme of SMDC.
Create and maintain different lists of favorite materials to quickly access from the catalog or maintain a list of materials for your project.
Update your material database view preferences.
Once the installation is complete, you must retrieve the administrator credentials.
Only an administrator will have access to SMDC Administrator Dashboard.
This chapter guides you how to launch and use the Authoring Tools in SMDC. It explains where to find these tools on the viewer page and the permissions you need to access them.
Add material data using Data Edit and Import Materials functionalities on Admin Dashboard.
Review imported material data to publish or unpublish the material in the database.
You can publish and unpublish material data to the database.
Add new metadata elements such as Material Type, Provider, Producer, Property, and Plot to define and organize material data in the database.
Administrators can preview, edit, add, delete, copy, and clone single-data, multi-data, plot data, numerical model values, and features of a material.
Modify the properties displayed in material tiles and tables. You can add, remove, or reorder property fields shown on the material tile (rows) and in the table view (columns) to suit your display preferences.
Here are the release notes for features and updates to Simcenter Material Data Center.
