View and Identify Source of the Data
Data for a given material can come from various sources. For complete traceability it is necessary to identify the source for each data. In SMDC labels allow you to view and clearly identify the source of the data.
Here are the different sources of data for materials in SMDC:
  • Manufacturer/Producer: The material producer supplies this data directly, and the system keeps it unaltered. It represents the verified dataset from the producer and appears without a label.
  • Generic: Generic materials, identical to trade products, can often be used to fill in the gaps in the data. In these cases, the borrowed data from a generic material is labeled as Generic.
  • Artificial Intelligence (AI): Data predicted by AI/Machine Learning (ML) algorithms. The system clearly labels this predicated data as AI.
