View Ziegler Material Information
View information for material pairs such as compatibility, name, quality, manufacturers, and brands.
Choose one of the following:
- Double-click the material.
- Hover over a material, click
The following compatibilities are assigned to each material pair:
- Good
Low-risk compatibility of
Squeak and is represented with a green color code. - Medium
Relatively lower risk compatibility and
is represented with a blue color code. - Poor
High-risk compatibility of
Squeak and is represented with a red color code.
A window opens to the right.Note: Click
to view the material information in
full screen mode.By default, the Summary tab displays the general information of the selected material.
Figure 1. View Ziegler Material Pairs Information
In the left panel, the Result Summary displays the compatibility details such as Risk Priority Number (RPN) and Impulse Rate of the selected material pairs.
Click Properties.
The material parts and their test results are displayed.
Figure 2. Material Properties
