PARAM, CM2
Bulk Data Entry Scale factor for direct input mass matrices.
Parameter Values Description
CM2 <Real>
Default = 1.0
CM2 specifies factors for the direct input mass matrix. The total mass matrix is:
⌊ M jj ⌋ = ⌊ M jj x ⌋ + CK 2 * ⌊ M jj 2 ⌋
Where,
⌊ M jj 2 ⌋
Is selected in the Subcase Information command M2GG.
⌊ M jj x ⌋
Is generated from the mass element entries in the Bulk Data section.
