PARAM, SIMDRIVE
Bulk Data Entry Controls the output of the <filename>._simdrive.h3d file directly from OptiStruct.
Parameter Values Description
SIMDRIVE <YES, BOTH>
Default: When this parameter is not defined in the input file, the corresponding SIMDRIVE H3D file is not generated.
If this parameter is input without a value, an error is issued.
YES
The <filename>._simdrive.h3d file is output. This is the SimDrive flexible body output in the H3D format. This H3D file contains the free-free modes (instead of the CMS modes) and the associated free-free results, such as stresses.
BOTH
The standard CMS H3D file is output along with the <filename>._simdrive.h3d file.
