PARAM, LFREQFL
Bulk Data Entry Excludes modes with frequencies lower than LFREQFL in Coupled Modal Frequency Response Analysis (Acoustic Analysis).
| Parameter | Values | Description |
| LFREQFL | <Real>
(Hertz) Default = None Defaults: If PARAM, LFREQFL is input without specifying a value, the solution runs into an error. |
Modes with frequencies less than LFREQFL are not used in Coupled Modal Frequency Response Analysis. LFREQFL can be used to remove Rigid Body Modes from the Modal Space. |
- Modes that are eliminated by PARAM, LFREQFL will display an "L" next to the mode number.
