Auto Fastener
Use the Auto Fastener tool to identify and pair holes to create fastener connectors between components and parts. The process works on 2D/3D mesh.
From the Connectors ribbon, Fastener tool group, click the Auto
Fastener tool.
- Select the parts to automatically add connectors to.
Click
on the guide bar and define
the following options.
- Hole Type
- The Hole types that will be looked for the in the model.
- Max hole dia
- The maximum allowable hole diameter.
- Min hole dia
- The minimum allowable hole diameter.
- Tolerance
- The distance between the holes.
- Max angle
- The angle between the normal to the holes.
- Allow holes to tubes
- Allow the connection between holes and tubes.
- Allow self
- If there are multiple holes on the same link that could be a part of the same stack.
- Center Connector
- Create the connector between the holes.
Click
on the guide bar.
The created output is connectors between the selected hole type taking into account the associated parameters. The connectors are in the unrealized state.
