Curves
Curve entities define and store xy data and are associated with a plot entity.
Curves do not have a display state. However, the display of a curve in a xy plot window is controlled by the display state and active state of its associated plot.
Abaqus Cards
| Card | Description |
| *AMPLITUDE | Define an amplitude curve Note: For Standard and Explicit profiles: The TABULAR definition reads either pairwise entries (new) or four pairs of values per dataline (old). The EQUALLY SPACED option has been updated to the new format as well. The old format is required by users using pre 6.9 Abaqus solver. The reader can read both formats. The card will be exported the same way as it was imported. The card image allows you to switch between both formats. |
EXODUS Cards
| Function | Time, frequency and/or spatially dependent functions for transient and frequency response analysis. |
LS-DYNA Cards
The output of curves creates a *DEFINE_CURVE or Structured Card 22 using Option 0.
*DEFINE_CURVE can be changed to *DEFINE_TABLE in the card previewer. When DEFINE_CURVE is changed to DEFINE_TABLE, the number of curves the table should contain depends on the XY curves that are referenced by a load, material, component, property, and so on are output.
Upon input, the *DEFINE_CURVE and *DEFINE_TABLE/Card 22 cards are read and placed in a plot called LS-DYNA Load Curves. Upon input, references to curves are preserved and are output along with the card, such as material, component, property and load.
| *DEFINE_CURVE | Define a curve. |
| *DEFINE_CURVE_SMOOTH | Define a smoothly varying curve using few parameters. |
| *DEFINE_CURVE_TRIM | Define a curve for trimming. |
| *DEFINE_CURVE_TRIM_3D | Define a curve for trimming. Trimming is processed based on the element normal rather than the vector. |
| *DEFINE_FUNCTION | Define a function that can be referenced by a limited number of keyword options. |
| *DEFINE_TABLE | Define a table. |
| *DEFINE_TABLE_2D | Define a table. |
| *DEFINE_TABLE_3D | Define a table. |
OptiStruct Cards
Multi-body dynamics curves are represented as curves.
| MBCRV | Specifies the data used to define a curve. Note: Bulk Data
Entry |
| TABDMP2 | Defines modal damping as a tabular function of mode index. Note: Bulk Data Entry |
| TABLED1 | Defines a tabular function for use in generating
frequency-dependent and time-dependent dynamic loads. Note: Bulk Data Entry |
| TABLED2 | Defines a tabular function for use in generating
frequency-dependent and time-dependent dynamic loads. Also contains parametric data
for use with the table. Note: Bulk Data Entry |
| TABLED3 | Defines a tabular function for use in generating
| TABLED4 | Defines the coefficients of a power series for use in
generating frequency-dependent and time-dependent dynamic loads. Also contains
parametric data for use with the table. Note: Bulk Data Entry |
| TABLEG | Defines a general tabular function for use in supported
reference entries. Note: Bulk Data Entry |
| TABLEM1 | Defines a tabular function for use in generating
temperature-dependent material properties. Note: Bulk Data Entry |
| TABLEM2 | Defines a tabular function for use in generating
temperature-dependent material properties. Also contains parametric data for use
| TABLEM3 | Defines a tabular function for use in generating
| TABLEM4 | Defines coefficients of a power series for use in
generating temperature-dependent material properties. Also contains parametric data
| TABLEMD | Defines a multi-dimensional tabular function which
identifies single or multiple X-values for a single Y-value. Note: Bulk Data Entry |
| TABLES1 | Defines a tabular function for use as stress-strain curve
in elasto-plastic material properties MATS1,
MATX33, MATX65, MATHF, as
well as material curve in nonlinear material properties MATX36,
MATX42, and MATX70. The
TABLES1 entry can also be used to define the corresponding
material curves on the MATHE Bulk Data Entry. Note: Bulk Data Entry |
| TABLEST | Specifies the material property tables for
elasto-plastic, temperature-dependent materials. Note: Bulk Data Entry |
| TABLEXN | Defines a tabular function for Stress (X) - Life (Y)
pairs to define an SN curve. Note: Bulk Data Entry |
PAM-CRASH Cards
| FUNCT/ | Definition of curves. |
| LOOKU / | Look up table cards. |
Permas Cards
| $FUNCTION | Function definition. |
Radioss Cards
| /FUNCT | Defines a function (For example: stress (Y-axis) as a
function of strain (X-axis)). Note: Block Format Keyword |
| /MOVE_FUNC | Describes the function scale and shift. Note: Block Format Keyword |
