Material Behaviors
This entity defines additional material features coupled to the referenced material, like: Failure, Permeability, Porosity, Thermal, Fatigue, Cohesive, Inelasticity, and so on.
Material Behaviors are referenced in the Material Entity Editor, which allows for a complete view of the material definition.
LS-DYNA Cards
- *MAT_ADD_AIRBAG_POROSITY
- *MAT_ADD_CHEM_SHRINKAGE
- *MAT_ADD_COHESIVE
- *MAT_ADD_DAMAGE_DIEM
- *MAT_ADD_DAMAGE_GISSMO
- *MAT_ADD_DAMAGE_GISSMO_STOCHASTIC
- *MAT_ADD_EROSION
- *MAT_ADD_FATIGUE
- *MAT_ADD_FATIGUE_EN
- *MAT_ADD_GENERALIZED_DAMAGE
- *MAT_ADD_INELASTICITY
- *MAT_ADD_PERMEABILITY
- *MAT_ADD_PORE_AIR
- *MAT_ADD_PROPERTY_DEPENDENCE_FREQ
- *MAT_ADD_PROPERTY_DEPENDENCE_TIME
- *MAT_ADD_PZELECTRIC
- *MAT_ADD_SOC_EXPANSION
- *MAT_ADD_THERMAL_EXPANSION
PAM-CRASH Cards
| Card | Description |
| NLAVE | Non-Local Average Option Definition, specifies a spatial averaging procedure for internal variables such as energy, stress and plastic strain . |
| RUPMO / | Rupture model definition. |
| RUPMO / IRUPT = 0 | Rupture Model Using Normal/Shear Load Criterion . |
| RUPMO / IRUPT = 1 | Rupture Model Using Stress Criterion . |
| RUPMO / IRUPT = 2 | Rupture Model Using a User-Defined Criterion for PLINKs . |
| RUPMO / IRUPT = 3 | Rupture Model Using a User-Defined Criterion for Spring-Beams . |
| RUPMO / IRUPT = 5 | Rupture Model Using a User-Defined Criterion for Spring-Beams . |
| RUPMO / IRUPT = 6 | EWK Rupture Model (only for Material Types 16 and 117) . |
| RUPMO / IRUPT = 7 | Rupture Model Using Loads Criterion (Weighted Bending) for Material Types 223 and 224 . |
| RUPMO / IRUPT = 11 | Rupture Models with User-Defined Criteria for Material Types 223, 224 and 302 . |
| RUPMO / IRUPT = 12 | Rupture Models with User-Defined Criteria for Material Types 223, 224 and 302 . |
| RUPMO / IRUPT = 13 | Rupture Models with User-Defined Criteria for Material Types 223, 224 and 302 . |
PAM-CRASH Failures
Failures describe material failure criteria to be coupled to material models.
In PAM-CRASH 2G, Damage and Failure parameters of Modular material MMAT are defined through the Failure entity.
| Card | Solver Description | Application | Notes |
| MMAT / FAILURE GLOBAL_BEHAVIOR |
Global Damage and Failure Parameters Definition | Elastic-plastic materials | Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT / |
| MMAT / FAILURE DUCTILE_CURVES |
Ductile Damage by Curves Parameters Definition | Elastic-plastic materials | Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT / |
| MMAT / FAILURE DUCTILE_LOOKU |
Ductile Damage by Look-Up Tables Parameters Definition | Elastic-plastic materials | Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT / |
| MMAT / FAILURE SHEAR_CURVES |
Shear Damage by Curves Parameters Definition | Elastic-plastic materials | Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT / |
| MMAT / FAILURE SHEAR_LOOKU |
Shear Damage by Look-Up Tables Parameters Definition | Elastic-plastic materials | Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT / |
| MMAT / FAILURE JOHNSON_COOK |
Johnson-Cook Failure Parameters Definition | Elastic-plastic materials | Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT / |
| MMAT / FAILURE XUE_WIERZBICKI |
Xue-Wierzbicki Failure Parameters Definition | Elastic-plastic materials | Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT / |
| MMAT / FAILURE MODIFIED_MOHR_COULOMB |
Modified Mohr-Coulomb Failure Parameters Definition | Elastic-plastic materials | Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT / |
| MMAT / FAILURE ANISOTROPIC_FRACTURE |
Anisotropic Fracture Failure Parameters Definition | Elastic-plastic materials | Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT / |
| MMAT / FAILURE FORMING_LIMIT_DIAGRAM |
Forming Limit Diagram Failure Parameters Definition | Elastic-plastic materials | Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT / |
| MMAT / FAILURE MUSCHENBORN_SONNE |
Müschenborn-Sonne Failure Parameters Definition | Elastic-plastic materials | Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT / |
| MMAT / FAILURE ENHANCED_HILL_STOREN_RICE |
Enhanced Hill-Stören-Rice Failure Parameters Definition | Damage and Failure Parameters | Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT / |
| MMAT / FAILURE GENERALIZED_NECKING |
Generalized Necking Failure Parameters Definition | Elastic-plastic materials | Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT / |
| MMAT / FAILURE PLASTIC_STRAIN_SOFTENING |
Plastic Strain Softening Failure Parameters Definition | Elastic-plastic materials | Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT / |
| MMAT / FAILURE HILL_STOREN_RICE |
Hill-Stören-Rice Failure Parameters Definition | Elastic-plastic materials | Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT / |
| MMAT / FAILURE MODIFIED_HILL_STOREN_RICE |
Modified Hill-Stören-Rice Failure Parameters Definition | Elastic-plastic materials | Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT / |
| MMAT / FAILURE RELATIVE_THICKNESS |
Relative Thickness Failure Parameters Definition | Elastic-plastic materials | Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT / |
| MMAT / FAILURE MAXIMUM_STRAINING |
Maximum Straining Failure Parameters Definition | Elastic-plastic materials | Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT / |
| MMAT / FAILURE PLASTIC_STRAIN_DAMAGE |
Plastic Strain Damage Parameters Definition | Elastic-plastic materials | Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT / |
| MMAT / FAILURE EXTENDED_COCKCROFT_LATHAM |
Extended Cockcroft-Latham Failure Parameters Definition | Elastic-plastic materials | Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT / |
| MMAT / FAILURE TABLE_DRIVEN_LOOKUP |
Data-Driven Look-Up Table Failure Parameters Definition | Elastic-plastic materials | Damage and Failure Parameters defined in a FAILURE - END_FAILURE cards block of MMAT / |
