Sequences
Sequence entities manage a list of composite ply type, orientation, thickness and
material layer data. Sequences have two configurations:
- Sequence: used to define repeating lists of composite layer data which can be paired with a ply shape and stacked in a laminate like plies.
- Zone: used to hold laminate zone data.
Sequence Configuration
The sequence configuration is used to define small repeating lists of layers in ply
based models.
- Sequences can be stacked in laminates like plies. Upon stacking, an instance sequence and instance plies are created and placed in the laminate at the desired location. Any changes made to the main sequence will propagate to instances stacked in laminates.
- A ply shape can be assigned to any instance sequence, or instance ply in an instance sequence. Ply shapes assigned to an instance sequence are passed to all instance plies. Ply shapes assigned directly to an instance ply override the instance sequence shape.
- Repeats are used to rapidly create and delete instance plies managed by the sequence. If set on the main sequence, the number of repeats propagates to all managed instance sequences. If set on an instance sequence, the number of repeats is unique to the instance.
| Option | Description |
| Main sequence | Only displayed if sequence is an instance. Select the main sequence which manages this instance sequence. |
| Repeats override | Only displayed if sequence is a main. If selected, main sequence controls the number of repeats for each instance sequence. |
| Repeats | Number of repeated sequences of plies to generate. If main sequence, only displayed if Repeats override is selected. If instance sequence, only displayed if Repeats override on instance’s main sequence is not selected. |
| Reverse sequence | Only displayed if sequence is an instance. Reverses the stack of all instance plies managed by the sequence. |
| Ply shape | Only displayed if sequence is an instance. A ply shape can be assigned to a sequence exactly like an individual ply. This assignment is passed to all instance plies managed by the instance sequence. Any ply which has a different ply shape directly assigned overrides this sequence ply shape assignment. |
Zone Configuration
| Element Ids | List of elements which make up this zone of constant layers in a laminate. |
