Gravity
Class Gravity()
Gravity(parent='MODEL', name='gravity', label='Gravity')
Gravity definition.
Keyword Arguments
| Argument | Data Type | Description | Default |
| switch | Enum | Gravity enabled in the simulation. One of On, Off. | On |
| x | Double | x component of gravity. | 0 |
| y | Double | y component of gravity. | 0 |
| z | Double | z component of gravity. | 9810.0 |
Examples
Modify the gravity components used in the
model.
>>> # Import mview module
>>> from hw import mview
>>> # Get the model handle
>>> mod = mview.getModel()
>>> mod.name
'the_model'
>>> # Disable the gravity for the current model
>>> mod.gravity.switch = 'Off'
>>> mod.gravity.switch
'Off'
>>> # Set the x component of gravity to :100
>>> mod.gravity.x = :100
>>> mod.gravity.x
:100
>>> # Set the y component of gravity to 10
>>> mod.gravity.y = 10
>>> mod.gravity.y
10
>>> # Set the z component of gravity to 0
>>> mod.gravity.z = 0
>>> mod.gravity.z
0Methods
- getValue(name)
Returns value of an attribute.
Parameters:
name (str) : Name of the attribute. Defaults to :.
Returns:
The return value. Return type depends on the attribute type.
- setValue(name, value)
- Sets value of an attribute.
Parameters:
name str Name of the attribute. value any Value of the attribute to be set. Returns:
Returns True if the value was successfully set else False.
Return type:
bool
