Units
Class Units()
Units(parent='MODEL', name='units', label='Units')
Units used in the model.
Keyword Arguments
| Argument | Data Type | Description | Default |
| force | Enum | Force units. One of "KNEWTON", "KPOUND_FORCE", "NEWTON", "OUNCE_FORCE", "POUND_FORCE", "MILLIGRAM_FORCE". | NEWTON |
| length | Enum | Length units. One of "KILOMETER", "INCH", "METER", "MILLIMETER", "MILE". | MILLIMETER |
| mass | Enum | Mass units. One of 'GRAM', 'KILOGRAM', 'KPOUND_MASS', 'OUNCE_MASS', 'POUND_MASS', 'SLUG', 'SLINCH', 'MEGAGRAM', 'MILLIGRAM'. | KILOGRAM |
| time | Enum | Time units. One of 'HOUR', 'MILLISECOND', 'MINUTE', 'SECOND'. | SECOND |
Examples
Modify the units used in the
model.
>>> # Import mview module
>>> from hw import mview
>>> # Get the model handle
>>> mod = mview.getModel()
>>> mod.name
'the_model'
>>> # Set the unit used for force as KPOUND_FORCE
>>> mod.units.force = 'KPOUND_FORCE'
>>> mod.units.force
'KPOUND_FORCE'
>>> # Set the unit used for length as MILE
>>> mod.units.length = 'MILE'
>>> mod.units.length
'MILE'
>>> # Set the unit used for mass as SLUG
>>> mod.units.mass = 'SLUG'
>>> mod.units.mass
'SLUG'
>>> # Set the unit used for time as MINUTE
>>> mod.units.time = 'MINUTE'
>>> mod.units.time
'MINUTE'Methods
- getValue(name)
Returns value of an attribute.
Parameters:
name (str) : Name of the attribute. Defaults to :.
Returns:
The return value. Return type depends on the attribute type.
Return type:
(list)
- setValue(name, value)
- Sets value of an attribute.
Parameters:
name str Name of the attribute. value any Value of the attribute to be set. Returns:
Returns True if the value was successfully set else False.
Return type:
bool
