Edit and Create an Advanced Search
Edit a criteria and create a new criteria by editing the existing criteria.
Click Advanced Search on the right pane.
The Advanced Search section is displayed.
Click
The Load Criteria dialog box is displayed with the list of saved criteria.Figure 1. Load Criteria
Select the required saved criteria.
The selected criteria is loaded and displayed in the Advanced Search section.
Edit the required search parameters.
Note: Click
to clear the search input values specified for the saved criteria.
Choose one of the following options:
- Click Save to update the selected criteria.
- Click Save As to create a new criteria.Note: If you click Save As, the Save As Search Criteria dialog box is displayed to provide a name to the new criteria.
