Materials Copilot Guide
Materials Copilot is an interactive, AI-powered chat assistant where the users can query the database using natural language. It is able to understand complex queries and find materials matching the users requirements.
Figure 1. Materials Copilot
Materials Copilot Menu Options
The Materials Copilot menu gives you quick access to manage your chat history and customize panel layout within the application. Use these options to ask questions, review previous conversations, and adjust the Copilot window to suit your workflow.
Figure 2. Materials Copilot Menu
  1. In the top-right corner of the application window, click Materials Copilot .
  2. In the Ask a question field, enter a question and press Enter or click the Send button to submit it.
    Note: Materials Copilot keeps track of the current and last question, so when you ask a follow-up question, you can assume it remembers the last question and response.
  3. Click Load Conversation to load your previous questions from your active chat.
  4. Click Toggle Info to toggle information from your active chat.
  5. Click Clear chat history to remove a question from your history.
  6. Click Undock Panel to undock or reposition the window to another location within the application.
  7. Click Dock Panel to reposition to its original location.
  8. Click Close Close to close Materials Copilot window.
Knowledge Resources
Materials Copilot uses an active internet connection to process your questions and can only return answers based on data contained in SMDC and some additional knowledge resources, such as the Altair Community Knowledge Base, Altair How-To video libraries, and Altair Learning materials, for example. It understands and responds in multiple languages, with the input language detected automatically. The coverage of Altair's knowledge resources is continuously expanding.
Note: Please do not submit questions that include personal or sensitive information.
In contrast with other AI chat solutions, the hallucination phenomenon—where the AI invents non-existent answers—is vastly minimized due to its constrained context approach. However, it can still retrieve an incorrect answer or fail to find the answer, depending on the specific qualities of the question and Altair’s own data sources.
