Use Generic Data to Fill Gaps
Generic material data can often be used to fill in missing data.
Generic materials are theoretical materials derived from product family data, such as polymers, and share similar properties and behaviors with other materials in the same category. They serve as reference data when the exact composition of a material is unavailable. Their characteristics are based on the known traits of related products, making their performance predictable.
To fill the missing data using generic data for a material:
  1. Select a material data set.
    In the following example, ABS material data set from Plastics is selected.
    The material database is filtered and displays the results.
  2. Click Details of a required material.
    A window opens to the right displaying the material information.
  3. To select the generic gap filling tool for a material, on the top-right corner, click Materials Intelligence > Generic data.
    The ABS generic data fills the missing property data for the selected material and is displayed in the Properties tab. The gap filled data with generic product data will be labelled as Generic.
  4. Click Plot to view the ABS generic plot data provided by the product Polymer > ABS.
  5. Select the plot curve value from the drop down list.
    The collected system data for the missing material property is displayed and is labelled as Generic.
