*aletanktests()
Creates an aletanktest in HMASCII format.
*aletanktests (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
- id
- The ID of the aletanktest.
- name
- The name of the aletanktest.
- color
- The color of the aletanktest. Valid values are 1-64.
To create an aletanktest with ID 100, name "my-entity", and color
1:
*aletanktests(100,"my-entity",1)Errors
Incorrect usage results in an import error.
Version History
2019
