*subsystemsets()
Creates a subsystemset in HMASCII format.
*subsystemsets (id, name, color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
- id
- The ID of the subsystemset.
- name
- The name of the subsystemset.
- color
- The color of the subsystemset. Valid values are 1-64.
To create a subsystemset with ID 100, name "my-entity", and color
1:
*subsystemsets(100,"my-entity",1)Errors
Incorrect usage results in an import error.
Version History
2020
