*freebodysections()
Creates a freebodysection in HMASCII format.
*freebodysections (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
- id
- The ID of the freebodysection.
- name
- The name of the freebodysection.
- color
- The color of the freebodysection. Valid values are 1-64.
To create a freebodysection with ID 100, name "my-entity", and color
1:
*freebodysections(100,"my-entity",1)Errors
Incorrect usage results in an import error.
Version History
2019.1
