*designpoints()
Creates a designpoint in HMASCII format.
*designpoints (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
- id
- The ID of the designpoint.
- name
- The name of the designpoint.
- color
- The color of the designpoint. Valid values are 1-64.
To create a designpoint with ID 100, name "my-entity", and color
1:
*designpoints(100,"my-entity",1)Errors
Incorrect usage results in an import error.
Version History
2019.1
