*resultsubcases()
Creates resultsubcases in HMASCII format.
*resultsubcases (id, name, color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
- id
- The ID of the resultsubcase.
- name
- The name of the resultsubcase.
- color
- The color of the resultsubcase. Valid values are 1-64.
To create a resultsubcase with ID 100, name "my-entity", and color
1:
*resultsubcases(100,"my-entity",1)Errors
Incorrect usage results in an import error.
Version History
2021.2
