*interfacepairlist()
Defines the interface pairs for a sub-laminate laminate.
*interfacepairlist (entity_ids)
HyperMesh HMASCII Command
- entity_ids
- The IDs that define the interface pairs for a sub-laminate laminate, separated by commas. Each pair consists of two IDs.
Examples
To create a sub-laminate laminate with ID 300, name "my-sub-laminate-laminate" and
sub-laminates 200 and
201:
*laminates(200,"my-sub-laminate-laminate",1,0,1,0)
*laminateidlistmax(2)
*laminateidlist(200,201)To add an interface to the above
laminate:
*interfacepairmax(1)
*interfacepairlist(200,201)Errors
Incorrect usage results in an import error.
Version History
11.0
