*responses()
Creates a response in HMASCII format.
*responses (id, name, color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
- id
- The ID of the response.
- name
- The name of the response.
- color
- The color of the response. Valid values are 1-64.
To create a response with ID 100, name "my-entity", and color
1:
*responses(100,"my-entity",1)Errors
Incorrect usage results in an import error.
Version History
2020
