*ice()
Creates an IC element in HMASCII format.
*ice (id,type,independentnodesmax,dependentnodesmax)
HyperMesh HMASCII Command
This must follow *component(). The element will be assigned to the most recent component created using *component().
*icelink must be used to define the independent nodes.
- id
- The ID of the element.
- type
- The solver specific element type.
- independentnodesmax
- The number of independent nodes.
- dependentnodesmax
- The number of dependent nodes.
To create an IC element with ID 500, independent nodes 100 and 101, node 100 dependent
nodes 200 and 300 with DOF 12, and node 101 dependent nodes 201 and 301 with DOF
123:
*ice(500,0,2,4)
*icelink(100,2,200,12,300,12)
*icelink(101,2,201,123,301,123)Errors
Incorrect usage results in an import error.
Version History
14.0
