HyperView LS-DYNA Results Reader
Supported Results
| Data Type Name | Result Type | Data Type | Notes |
| Displacement | NODE | VECTOR | |
| Velocity | NODE | VECTOR | |
| Acceleration | NODE | VECTOR | |
| Temperature | NODE | SCALAR | |
| Energy Results | NODE | SCALAR | Supported energy results include internal energy, hourglass energy. |
| Time step related results | NODE | SCALAR | Supported results include time step size, mass scaling. |
| CFD Data | NODE | SCALAR | Supported CFD types include pressure, vorticity (x, y, z, and resultant), entropy, helicity, stream function, enthalpy, density, turbulent kinetic energy, and dissipation. |
| Particle Data | NODE/PARTICLE | VECTOR/SCALAR | Supported particle results include displacement, velocity, spin energy, translational energy, radius, leakage, and gas ID. |
| Residual Forces and Moments | NODE | VECTOR | |
| Normal resultant force | ELEMENT (1D, 2D) | VECTOR | |
| Shear resultant force | ELEMENT (1D, 2D) | VECTOR | |
| Bending Moment | ELEMENT (1D, 2D) | VECTOR | |
| Stress | ELEMENT (1D, 2D, 3D) | TENSOR3-D | Thick shell support is for the mid-surface only. |
| Strain | ELEMENT (1D, 2D, 3D) | TENSOR3-D | Thick shell support is for the inner surface only. |
| Plastic Strain | ELEMENT (1D, 2D, 3D) | TENSOR3-D | Thick shell not supported. |
| Thermal Strain | ELEMENT (1D, 2D, 3D) | TENSOR3-D | Thick shell not supported. |
| Effective plastic strain | ELEMENT (1D, 2D, 3D) | SCALAR | Thick shell support is for the mid-surface only. |
| Pressure | ELEMENT (1D, 2D, 3D) | SCALAR | Thick shell support is for the mid-surface only. |
| Thickness | ELEMENT (2D) | SCALAR | |
| Percent thinning | ELEMENT (2D) | SCALAR | |
| Interface force in global direction | NODE | VECTOR | Supported from INTFORC file |
| Interface force - Normal | NODE | SCALAR | Supported from INTFORC file |
| Interface force - Surface | NODE | SCALAR | Supported from INTFORC file |
| Contact Gap | NODE | SCALAR | Supported from INTFORC file |
| Interface shear stress | ELEMENT | SCALAR | Supported from INTFORC file, includes shear stress in r and s direction |
| Interface pressure - Normal | ELEMENT | SCALAR | Supported from INTFORC file |
| Interface force-segment | ELEMENT | VECTOR | Supported from INTFORC file (For Fluid structure interaction) |
| Interface pressure-segment | ELEMENT | SCALAR | Supported from INTFORC file(For Fluid structure interaction) |
| Peak Pressure | ELEMENT | SCALAR | Supported from INTFORC file |
| Time to peak | ELEMENT | SCALAR | Supported from INTFORC file |
| Surface energy density | ELEMENT | SCALAR | Supported from INTFORC file |
Note:
- HyperView supports LS-DYNA version up to R11.1
- HyperView supports implicit results
- You can request specific information in the LS-DYNA run to output results, such as beam and strain, in HyperView
- Corner data results (solids with multiple integration points) are supported
