HyperView LS-NIKE3D Result Reader
Supported Results
| Data Name | Components | Result Type | Data Type |
| Displacement | NODE | VECTOR | |
| Velocity | NODE | VECTOR | |
| Acceleration | NODE | VECTOR | |
| Temperature | NODE | SCALAR | |
| Stress | ELEMENT | TENSOR3-D | |
| Strain | ELEMENT | TENSOR3-D | |
| Effective plastic strain | ELEMENT | SCALAR | |
| Thickness | ELEMENT | SCALAR | |
| 2-D Force | mxx bending moment | ELEMENT | SCALAR |
| myy bending moment | ELEMENT | SCALAR | |
| mxy bending moment | ELEMENT | SCALAR | |
| qxx shear resultant | ELEMENT | SCALAR | |
| qyy shear resultant | ELEMENT | SCALAR | |
| nxx normal resultant | ELEMENT | SCALAR | |
| nyy normal resultant | ELEMENT | SCALAR | |
| nxy normal resultant | ELEMENT | SCALAR | |
| 1-D Force | Axial force | ELEMENT | SCALAR |
| S shear resultant | ELEMENT | SCALAR | |
| T shear resultant | ELEMENT | SCALAR | |
| S bending moment | ELEMENT | SCALAR | |
| T bending moment | ELEMENT | SCALAR | |
| Torsional resultant | ELEMENT | SCALAR |
Note: The Nike3-D reader supports element results at nodal and centroidal positions. If
integration point results for brick elements are available, then they are pushed to the
nearest corners. Centroidal results are calculated by averaging the integration point
results.
