HyperView PAM-CRASH 2G Results Reader
Supported Results
| Data Name | Result Type | Data Type | Keyword | Notes |
| Structural | ||||
| Displacement | NODE | VECTOR | ||
| Velocity | NODE | VECTOR | ||
| Pressure | NODE | VECTOR | Contact Pressure, CTCPR | |
| Max normal pressure | NODE | VECTOR | Normal Pressure, CTCMP | |
| Mass Increase Factor | NODE | SCALAR | Mass Increase, N5 | |
| Increased Mass | NODE | SCALAR | Increased Mass, N6 | |
| Stress | ELEMENT | TENSOR3-D | SXYZ | 3-D |
| Equivalent Plastic Strain | ELEMENT | SCALAR | EPLE | 3-D |
| Int. Energy Density | ELEMENT | SCALAR | INED | 3-D, 2-D |
| HG Energy Density | ELEMENT | SCALAR | HGED | 3-D, 2-D |
| Solid Aux | ELEMENT | SCALAR | 3-D, up to 6 additional scalar values | |
| Max equiv. stress o. thickness | ELEMENT | SCALAR | ESMA | 2-D |
| Min equiv. stress o. thickness | ELEMENT | SCALAR | ESMI | 2-D |
| Max plastic strain o. thickness | ELEMENT | SCALAR | EPMA | 2-D |
| Min plastic strain o. thickness | ELEMENT | SCALAR | EPMI | 2-D |
| Moment local | ELEMENT | TENSOR2-D | MXYZ | 2-D |
| Membrane stress res. local | ELEMENT | TENSOR2-D | NXYZ | 2-D |
| Lower S strain | ELEMENT | TENSOR2-D | EPSI_lower | 2-D |
| Upper S strain | ELEMENT | TENSOR2-D | EPSI_upper | 2-D |
| Lower S stress | ELEMENT | TENSOR2-D | SIGM_lower | 2-D |
| Upper S stress | ELEMENT | TENSOR2-D | SIGM_upper | 2-D |
| Membrane stress | ELEMENT | TENSOR2-D | SIGM_membrane | 2-D |
| Membrane plastic strain | ELEMENT | SCALAR | EPME | 2-D |
| Membrane strain rate | ELEMENT | SCALAR | STRA | 2-D |
| Membrane VM Stress | ELEMENT | SCALAR | ESME | 2-D |
| Thickness | ELEMENT | SCALAR | THIC | 2-D |
| Thinning | ELEMENT | SCALAR | THIN | 2-D |
| Total Damage | ELEMENT | SCALAR | DMG | 2-D |
| Axial Force | ELEMENT | SCALAR | FAXI | 1-D |
| Transverse S shear force | ELEMENT | SCALAR | FSSH | 1-D |
| Transverse T shear force | ELEMENT | SCALAR | FTSH | 1-D |
| Torsion Moment | ELEMENT | SCALAR | MTOR | 1-D |
| S Moment at n1 | ELEMENT | SCALAR | MSN1 | 1-D |
| T Moment at n1 | ELEMENT | SCALAR | MTN1 | 1-D |
| S Moment at n2 | ELEMENT | SCALAR | MSN2 | 1-D |
| T Moment at n2 | ELEMENT | SCALAR | MTN2 | 1-D |
| Axial Elongation | ELEMENT | SCALAR | DAXI | 1-D |
| R Torsion angle | ELEMENT | SCALAR | RTOR | 1-D |
| S Bending rotation at n1 | ELEMENT | SCALAR | RSN1 | 1-D |
| T Bending rotation at n1 | ELEMENT | SCALAR | RTN1 | 1-D |
| S Bending rotation at n2 | ELEMENT | SCALAR | RSN2 | 1-D |
| T Bending rotation at n2 | ELEMENT | SCALAR | RTN2 | 1-D |
| Minimum Hill Stress | ELEMENT | SCALAR | Component | |
| Maximum Hill Stress | ELEMENT | SCALAR | Component | |
| Membrane Hill Stress | ELEMENT | SCALAR | Component | |
| Distance to FLD | ELEMENT | SCALAR | Component | |
| Wrinkle Criterion | ELEMENT | SCALAR | Component | |
| Material Internal Energy | ELEMENT | SCALAR | Component | |
| Material Kinetic Energy | ELEMENT | SCALAR | Component | |
| Material Hourglass Energy | ELEMENT | SCALAR | Component In case of Beam components, this represents bending energy. |
| Bending Energy Density | ELEMENT | SCALAR | Component | |
| Membrane Energy Density | ELEMENT | SCALAR | Component | |
| Transverse Shear Energy Density | ELEMENT | SCALAR | Component | |
| Material Equivalent Membrane Energy | ELEMENT | SCALAR | Component |
Note:
- HyperView reader supports Femzip ERF (HDF5) results, femzip library version 6.1.3019.
- HyperView supports DSY and ERFH5 (HDF5) files.
- Reading of ERHF5 (HDF5) files are supported only in Windows and Linux platforms.
- HyperView and HyperGraph uses same ERFH5 result reader to support ERF (HDF5) results. In 2019, PAM-CRASH ERF reader enhanced to support ERF (HDF5) results that use modular input definition. Introduced entity pools to handle duplicate IDs shared across different modules in the same model. These entities will be represented by their module IDs along with their parent entity module IDs.
- HyperView can read a model, but not results, from THP files.
- The PAM-CRASH ERF (HDF5) and DSY readers are enhanced to handle higher version result files.
- HyperView uses the same naming convention as PAM-VIEW.
- HyperView supports files created on NT, LINUX, SGI, HP, SUN, IBM, FUJITSU, and NEC platforms.
- HyperView can read a model from a PAM-CRASH 2G input deck.
- HyperView can read zipped DSY files of PAM-CRASH 2G using FEMZIP libraries v11.00 or older version.
