Animate Shapes
Animate selected shapes.
From the Morph ribbon, click the Shapes tool.
The Edit Shapes dialog opens. - Select a shape.
Click
The Edit Shapes dialog closes and the Shape Animation toolbar displays.Figure 2.
Set playback options as necessary by clicking
- Set Playback to loop, bounce, or once.
- Place a check in the Contour Plot checkbox to display the plot.
- Type a value for the desired number of frames.
- Type a value for the Animation speed.
- Type a value for Scale factor. This will change the height of the animation.
- Play, pause, or rewind the animation using the playback tools on the toolbar.
Redisplay the model in its current shape factor by clicking
To return to the Edit Shapes dialog, click
