Create Shapes
Create and apply morphing shapes. Shapes can be created by morphing or by converting load collectors.
From the Morph ribbon, click the Shapes tool.
The Edit Shapes dialog opens. -
Click
in the
top, left of the dialog to save the morph as a shape.
- Toggle the Preview option to view the initial state of the model vs the morphed state of the model.
- Optional: Activate the Design Variable option and define a lower bound, initial value, and upper bound to use the shape in subsequent design optimization studies.
With the preview applied, right-click on the shape and select Apply
Preview to save the morph.
The morph is compounded each additional time you view and apply the preview.
Tip:
- Toggle
to
show/hide the vectors that define the shape. - Activate the Preview option of two or more shapes and
click
to
combine the morphs into a new shape. - To quickly create shapes without disrupting the morphing workflow, click the
Create Shapes satellite icon.
Create Shapes from Loads
Create a new shape for each selected load collector with the force vectors at each node of each load collector converted into XYZ perturbations at each node for each shape.
The original load collector will be preserved.
The Edit Shapes dialog opens. - Right-click in the Edit Shapes dialog and select Create from Loads from the context menu.
- Select the Load Collectors (forces, temperatures, pressures, enforced displacements) to convert into shapes.
- Click Create.
