Customize Columns for Table View
Add, remove, or reorder property columns shown in the Table view.
  1. Go to SMDC Application Catalog > Data Table > Table to view the current list of table columns.
    Figure 1. Customize Table View
  2. To add a property column, drag and drop it from the Base Catalog to this list.
  3. To reorder columns, drag and rearrange them as needed.
  4. To remove a column, click next to the property and select Delete Item.
    Figure 2. Delete Item
    Delete Item
