Extensions
Enhancements
Extension Script Statement Profile Support
Both Python and Tcl scripts are now supported in all profiles with one script statement: <entry name="script" value="init.py" />.
Extension Documentation
The documentation for how to use Python commands in the ribbon.xml and toolbar.xml files has been updated.
Resolved Issues
  • The empty icons in the extensions drop-down menus no longer appear when images are specified in the actions of the menu.xml file.
  • An exception error is no longer seen upon reloading the demo extension in solver profiles other than OptiStruct and Nastran.
  • A load script error no longer crashes the application when removing an extension that would previously trigger such an error.
  • Loading an extension using the HyperWorks GUI Toolkit now works either with an extension.xml file or a (deprecated) plugin.xml file.
