Meshing
Enhancements
- Performance
- Performance of the Rebuild tool in large models is now 30% - 50% faster. Some examples include: FE geometry topology operations, box trim, cut hole, Bead tool, and many more.
- Topology: Cleanup Tolerance Preference
- The Automatic and Manual options have been removed.
- Features
- FE geometry support has been added for flange detection.
- Split/Stitch Tool
- A new option has been added to split an FE geometry solid or surface using elements.
