Engine Model
Symbols used:
| Engine Speed [State] | ![]() |
| Transmission Ratio | ![]() |
| Engine Inertia | ![]() |
| Transmission RPM | ![]() |
| Engine Torque | ![]() |
| Transmission Inertia | ![]() |
The engine is modelled as a black-box that produces a torque based on the current throttle
position (input) and engine speed (state). The rotational inertia of all the rotating
components of the engine is lumped in
The torque to accelerate the engine’s rotating components is the difference between the
torque the engine produces, and torque reacted by the clutch. Hence the derivative of the
engine speed is given by:
The engine torque is:
is interpolated from a 3-D spline that is an input in the
.pwr file.
