mdlIObject BeginChildFastGet
Obtains a list for a particular entity type and then later obtains a handle for one of its child objects.
mdlIObject_handle BeginChildFastGet show_folders, show_datamembers, show_references, (filter)
MotionView Tcl Query
This command obtains a list for a particular entity type and then later obtains a handle
Note: The GetNumberOfChildren and
GetChildHandleByIdx commands can be used in context of
BeginChildFastGet/EndChildFastGet to obtain the
number of children and their corresponding handles.
- show_folders
- True
- If you want to build folders into the list, for example, the Points folder and Bodies folder will appear in the browser.
- show_datamembers
- True
- Enables data members to be shown.
- False
- Will cause data members to be skipped over.
- show_references
- True
- Enables reference data members to be shown, otherwise they are hidden.
- filter
- Used for filtering objects into the list. For example, if you type "Points", you will pass "Point" into the list, or if you want just points and bodies, you can type "Point/Body".
To get the list of children on the model:
hwi OpenStack
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName BeginChildFastGet False True True ""
myModelName GetNumberOfChildren
for { set idx 1 } { $idx <= [myModelName GetNumberOfChildren] } {incr idx } {
myModelName GetChildHandleByIdx child_handle $idx;
puts "[child_handle GetVarname]";
child_handle ReleaseHandle;
myModelName EndChildFastGet;
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandle
hwi CloseStackErrors
Returns 0 if successful, otherwise an error code.
