mdlIObject IsDataSetData
Determines whether or not the entity belongs to a DataSet.
mdlIObject_handle IsDataSetData
MotionView Tcl Query
This command determines if the entity is a member of a DataSet or not.
To check to see if an entity is a member of a DataSet:
    hwi OpenStack
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName InterpretEntity ds_handle DataSet ds_0 "\"DataSet 0\"" ds_def_0
ds_handle  InterpretEntity int_handle Integer int_0 \"INTEGER1\"
int_handle IsDataSetData  #It returns true
ds_handle IsDataSetData #It returns false
int_handle ReleaseHandle;
ds_handle ReleaseHandle;
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandle
hwi CloseStackErrors
Returns true if the object belongs to a DataSet, or false if it is not.
