mdlIObject InterpretEntity
Adds a new entity using the MDL statements keyword, variable name, and label.
mdlIObject_handle InterpretEntity new_handle, keyword, varname, label
MotionView Tcl Modify
This command adds a new entity using the MDL statements keyword, variable name, and label. You can specify the new entity's type, variable name, and label, as well as other topology arguments.
- new_handle
- The handle for the new entity.
- keyword
- The new entity's MDL statement keyword.
- varname
- The new entity's variable name.
- label
- The new entity's label.
To create a new body (b_0) with the label "My
Body":
hwi OpenStack
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName InterpretEntity new_handle Body b_0 "\"My Body\" "
new_handle ReleaseHandle
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandle
hwi CloseStackErrors
Returns 0 if successful, otherwise an error code.
