mdlIObject InterpretSet
Adds a new set statement to the system.
mdlIObject_handle InterpretSet keyword, tokens
MotionView Tcl Modify
This command adds a new set statement to the system. You must specify all tokens for the requested MDL set statement.
- keyword
- The new entity's MDL statement keyword.
- tokens
- The remaining tokens for the corresponding MDL statement.
To get a handle to the parent system of the point p_0:
Note: The mdlIObject
InterpretSet command is used to set the x, y, and z expression for that
point.
hwi OpenStack
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName InterpretEntity point_handle Point p_0 "\"My Point\" "
point_handle InterpretSet SetPoint p_0 "1+1" "2+2" "3+3"
point_handle ReleaseHandle
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandle
hwi CloseStackErrors
Returns 0 if successful, otherwise an error code.
