mdlIObject IsPair
Determines if an object is a pair entity.
mdlIObject_handle IsPair
MotionView Tcl Query
This command determines if an object is a pair entity.
To check if an object is a single or a pair entity:
Note: Load the
slider_crank.mdl model file before running this
example.
hwi OpenStack
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName GetChildHandle point_handle p_conrod_cg0
point_handle IsPair
point_handle ReleaseHandle
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandle
hwi CloseStackErrors
Returns true if the object is a pair entity, otherwise false.
