mdlIObject SaveAs
Saves the model to a specified file.
mdlIObject_handle SaveAs file_name
MotionView Tcl Modify
This command saves the model to a new file which is given as an input to the command.
- file_name
- The full path of the file where the model is to be saved.
To save a the model to a specified file:
Note: Copy the
slider_crank.mdl model file into the present working directory
before running this
example.
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName CreateModel slider_crank.mdl
myClientName GetModelHandle myModelName
myModelName GetObjectHandle obj_handle
obj_handle InterpretEntity en Point p_0 "\"Point 0\""
en ReleaseHandle
obj_handle SaveAs {C:\temp.mdl}
obj_handle ReleaseHandle;
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandleErrors
Returns 0 if successful, otherwise an error code.
