mdlIObject SetSelectionType
Sets the selection type of an Assembly or external Analysis.
mdlIObject_handle SetSelectionType def_type
MotionView Tcl Modify
This command sets/updates the ‘selection_type’ data member of an object. The object on which this command will be called should be an external Analysis or Assembly.
- def_type
- The definition type that the ‘selection_type‘ data member will be set to.
To set the ‘selection_type’ data member of an object:
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName GetObjectHandle obj_handle
obj_handle AddNewAssembly assem_handle assem_0 "\"Assembly 0\"" C:/temp/data_file.mdl C:/temp/def_file.mdl true assem_def_name assem_type;
assem_handle SetSelectionType assem_new_type
assem_handle ReleaseHandle;
obj_handle ReleaseHandle;
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandleErrors
Returns 0 if successful, otherwise an error code.
