mdlIObject GetCandidateList
Gets the list of attachment candidates which can be resolved to an attachment based on the attachment tag.
mdlIObject_handle GetCandidateList local_only
MotionView Tcl Query
This command obtains the list of attachment candidates based on the attachment tag.
- local_only
- Argument can be ‘true’ or ‘false’.
- True
- Returns all resolved attachment candidate references
- False
- Returns all attachment candidates.
To obtain the list of attachment candidates based on the attachment
tag:
hwi OpenStack
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName InterpretEntity sys_handle System sys_0 \"System\" def_sys_0
sys_handle AddAttachment att_handle att_1 "\"Attachment 1\"" Body "RUN"
myModelName InterpretEntity bd_handle Body b_0 \"Body 0\"
myModelName InterpretEntity cand_handle AttachmentCandidate cand_1 "\"Test\"" b_0
myModelName InterpretSet SetAttachmentCandidateTag cand_1 "RUN"
myModelName GetCandidateList false #It returns MODEL.sys_0._att1_att MODEL.b_0
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandle
hwi CloseStackErrors
Returns the candidate list if successful.
