mdlIObject ReplaceEntityAdvanced
Replaces an existing entity with a new entity using MDL statement keywords and the remaining statement tokens.
mdlIObject_handle ReplaceEntityAdvanced new_handle, old_handle, keyword, tokens
MotionView Tcl Modify
This command replaces an existing entity with a new entity using MDL statement keywords and
Note: The variable name and label for the new entity are
copied from the old entity. You can specify the type for the replacement entity and any
other token used in the MDL statement (other than the variable name and label).
- new_handle
- The handle for the new entity.
- old_handle
- The handle of the current entity.
- keyword
- The entity's MDL statement keyword.
- tokens
- The remaining tokens for the corresponding MDL statement.
To append a floating marker on B_Ground at the global origin, then use the
mdlIModel ReplaceEntityAdvanced command to replace that floating marker
with a floating marker on B_Ground, but at
p_0.r:
hwi OpenStack
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName InterpretEntity pt0 PointPair p_0 "\"Point Pair\"";
myModelName InterpretSet SetPoint p_0 "" 0.0 50.0 50.0 0.0 -50 50;
myModelName InterpretEntity mark_handle Marker mrk_0 "\"Marker 0\"" B_Ground P_Global_Origin "FLOATING";
pt0 ReleaseHandle;
myModelName Evaluate;
myModelName BeginFlatListFastGet "Point"
myModelName GetChildHandleByIdx point_handle 2
set pointvar [point_handle GetFullVarname]
tk_messageBox -message "$pointvar";
myModelName EndChildFastGet
myModelName ReplaceEntityAdvanced newmark_handle mark_handle Marker B_Ground $pointvar Floating;
newmark_handle ReleaseHandle
point_handle ReleaseHandle
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandle
hwi CloseStackErrors
Returns 0 if successful, otherwise an error code.
or
Returns the name of the new_handle (in the example above it returns "newmark_handle").
