mdlIObject IsAssembly
Determines if an object is an assembly or not.
mdlIObject_Handle IsAssembly
MotionView Tcl Query
This command determines if an object is an assembly or not.
To check if an object is an assembly:
hwi OpenStack
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName GetChildHandle myAssembly assem_0
set val [myAssembly IsAssembly];
tk_messageBox -message "This Object is an Assembly: $val";
myAssembly ReleaseHandle;
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandle
hwi CloseStackErrors
Returns true if the object is an assembly, otherwise false.
