mdlIObject GetChildHandleByIdx
Obtains the handle of the child object using its index value.
mdlIObject_handle GetChildHandleByIdx child_handle, index
MotionView Tcl Query
This command obtains the handle of the child object using its index value. This handle can further be used to edit the properties of the entity.
- child_handle
- The handle name of the child.
- index
- The index number of the child whose handle is desired.
To get the handle of a mass of a body using an index number and then change its
value:
hwi OpenStack
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName BeginFlatListFastGet Body
myModelName GetChildHandleByIdx body_handle 2
body_handle GetChildHandle mass_handle mass
set body_mass [mass_handle GetEvaluatedValue]
set new_mass [expr $body_mass + 10];
mass_handle SetRawExpression $new_mass
mass_handle Evaluate
mass_handle ReleaseHandle
body_handle ReleaseHandle
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandle
hwi CloseStackErrors
Returns the name of the child handle if successful, otherwise an error code.
