mdlIObject GetParentHandle
Gets back the parent handle from its child.
mdlIObject_handle GetParentHandle handle_name
MotionView Tcl Query
This command gets back the parent handle from its child. This is useful when you have forgotten the parent handle name and still want to get the parent handle back.
- handle_name
- The new handle name of the parent handle.
To get the point handle from its x-coordinate handle and then use this new handle to get
the y-coordinate handle:
Note: Load the slider_crank.mdl model file
before running this
example.
hwi OpenStack
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName GetChildHandle point_handle p_sp
point_handle GetChildHandle xhandle x
set xval [xhandle GetEvaluatedValue]
xhandle SetRawExpression " [expr $xval + 20]"
xhandle GetParentHandle pt_handle
pt_handle GetChildHandle yhandle y
yhandle SetRawExpression "[expr [yhandle GetEvaluatedValue] + 30]";
yhandle ReleaseHandle;
xhandleReleaseHandle;
point_handle ReleaseHandle;
pt_handle ReleaseHandle;
myModelName ReleaseHandle;
myClientName ReleaseHandle;
myWindowName ReleaseHandle;
myPageName ReleaseHandle;
myProjectName ReleaseHandle;
mySessionName ReleaseHandle;
hwi CloseStackErrors
Returns the handle of the parent object.
