mdlIObject SaveObject
Saves the model to a specified location.
mdlIObject_handle SaveObject
MotionView Tcl Modify
This command saves the model to a specified location.
To save an object/model:
Note: Load the slider_crank.mdl model file
before running this
example.
hwi OpenStack
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName SaveObject "C:/slider_crank_new.mdl" ; #Or specify the pathname that you require#
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandle
hwi CloseStackErrors
Returns 0 if successful, otherwise an error code.
