Bulk Data Entries by Function
Guidelines for using Bulk Data Entries are listed in Bulk Data Guidelines.
The following table lists Bulk Data Entries according to data
type.
| Data Type | Bulk Data Entry | |
| Optimization | BMFACE | DSCREEN |
| Aero | AECOMP | DMI |
| Arbitrary Beam Section | BEGIN | CSEC8 |
| Bodies | RBADD | RBODY |
| Constraints | INLTVEL | SPC1 |
| Coordinate Systems | CORD1C | CORD2R |
| Contact | CLRNC | PCONT |
| Eigenvalue Analysis | EIGC | EIGRD |
| Elements | CAABSF | |
| Fatigue Analysis | FATDEF | MATFAT |
| Fluid Structure Modeling | ACMODL | FSI |
| Frequency Response Loads | ACSRCE | SLOAD |
| Grid and Scalar Points | GRID | SPOINT |
| Heat Transfer Boundary Conditions | CHBDYE | QBDY1 |
| Includes | INCLUDE | |
| Materials | MAT1 | MATMDS |
| Matrix Input | DMIG | EL2MAT |
| Modal Damping | HYBDAMP | TABDMP1 |
| Matrix Reduction | ASET | EXTRN |
| Metadata | METADATA | |
| Miscellaneous | CYAX | |
| Model Checks | ELEMQUAL | |
| Multibody Dynamics Entities | CMBEAM | CMSPDPT |
| Multibody Dynamics Joints and Contacts | JOINT | MBCVCV |
| Multibody Dynamics Loads and Motions | INVELB | MBSMNT |
| Multibody Dynamics Simulations and Requests | MBACT | MBREQM |
| Nonlinear Analysis | BASELIN | NLENRG |
| Explicit Analysis | ||
| Non-structural Mass, Damping | NSGE | NSM1 |
| One-step Stamping | BLKHDF | FLDATA |
| Parameters | GAPPRM | |
| Parts and Instances | INSTNCE | |
| Ply-based Composite Laminates | DRAPE | STACK |
| Pretensioned Analysis | PRETENS | PTADJST |
| Properties | HOURGLS | |
| Random Response | RANDPS | RCROSS |
| Response Spectrum | DTI,SPECSEL | RSPEC |
| Rotor Dynamics | RGYRO | RSPINR |
| Set Definition | SET | |
| Solver Selection | SOLVTYP | |
| Special Outputs | BORE | PEAKOUT |
| Static Loads | ACCEL | MOMENT2 |
| Transient Nonlinear Loads | DAREA | NOLIN4 |
| Units | DTI,UNITS | |
