hm_addchildrenoflistsinmark
Add children entities of lists in a mark.
hm_addchildrenoflistsinmark mark_id recursive references_mode
HyperMesh Tcl Query Command
- mark_id
- The ID of the mark. Valid values are 1 and 2.
- recursive
- 0 - Do not return children entities of children lists
- references_mode
- Determines how to compute entities referred by children entities:
Examples
To populate mark 1 without
recursion:
hm_addchildrenoflistsinmark 1 0 0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2020
