hm_getmodelcheckfailedcount
Returns the number of entities failing a given model checker check.
hm_getmodelcheckfailedcount check_name
HyperMesh Tcl Query Command
- check_name
- The name of the check, as given in the model checker config file.
To get the number of entities failing the "Number of defined materials" check:
hm_getmodelcheckfailedcount "Number of defined materials"
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2017.1
