hm_jobs_setServiceProperty
Sets a service property for the PBS-sensor.
hm_jobs_setServiceProperty service_name value
HyperMesh Tcl Query Command
Sets a service property for the PBS-sensor. This is useful for changing the start-up time, log info, and so on.
- service_name
- The name of the service to update.
- value
- The value to update to.
Examples
To set a service property to increase the start-up time to
240:
hm_jobs_setServiceProperty "startup_timeout" 240To write the debug logs to user
directory:
hm_jobs_setServiceProperty "debug" trueTo start the PBS-sensor
implicitly:
hm_jobs_setServiceProperty "implicit_start" trueErrors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0.130
