hm_jobs_canSubmit
Reports if a job can be submitted on the current server without authentication.
hm_jobs_canSubmit name
HyperMesh Tcl Query Command
Checks if a job can be submitted on the server without authentication. If a server is already authenticated in a session, the next time a job is submitted to the same server by the same user authentication is not required. Returns 0 if authentication is required, 1 otherwise.
This is not applicable for local job submission.
- name
- The name of the server to query.
To query server HWUL:
hm_jobs_canSubmit HWUL
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0.130
